Saturday,07,April,2018,11:16:21:62939
Address 01: Engine Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 LF HW: 03L 906 022 G
Component and/or Version: R4 2,0L EDC G000SG 3691
Software Coding: 0000071
Work Shop Code: WSC 01120 259 999999
VCID: 74E73A5B174EF4BE80B-8021
5 Faults Found:
000289 - Throttle Position Sensor (G69)
P0121 - 000 - Implausible Signal - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 21
Reset counter: 255
Mileage: 133265 km
Time Indication: 0
Date: 2041.14.24
Time: 14:41:26
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.84 V
Lambda: 84.4 %
Lambda: -0.8 %
Bin. Bits: 00001110
Voltage: 3.648 V
001027 - EGR Valve (N18)
P0403 - 000 - Malfunction - Intermittent
Fault Priority: 2
Fault Frequency: 7
Reset counter: 255
Mileage: 133977 km
Time Indication: 0
Date: 2042.14.17
Time: 17:11:25
RPM: 1656 /min
Speed: 44.0 km/h
Load: 3.5 %
Load: 14.9 %
Lambda: 46.6 %
Mass Air / Rev.: 330.0 mg/str
Temperature: 54.9°C
008465 - Throttle Actuator Control System
P2111 - 000 - Stuck Open - MIL ON
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 134051 km
Time Indication: 0
Date: 2042.14.20
Time: 10:00:46
RPM: 1978 /min
Speed: 103.0 km/h
Load: 45.1 %
Load: 12.5 %
Lambda: 100.2 %
Mass Air / Rev.: 655.0 mg/str
Temperature: 85.5°C
008466 - Throttle Actuator Control System
P2112 - 000 - Stuck Closed - Intermittent
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 134071 km
Time Indication: 0
Date: 2042.14.20
Time: 10:17:04
RPM: 2231 /min
Speed: 116.0 km/h
Load: 47.1 %
Load: 13.7 %
Lambda: 60.8 %
Mass Air / Rev.: 690.0 mg/str
Temperature: 88.2°C
005215 - Mass Air Flow during Regeneration too High
P145F - 000 -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 134071 km
Time Indication: 0
Date: 2042.14.20
Time: 10:17:01
RPM: 1932 /min
Speed: 76.0 km/h
Voltage: 14.14 V
Load: 100.0 %
Load: 11.8 %
Mass Air / Rev.: 365.0 mg/str
Mass Air / Rev.: 710.0 mg/str
Readiness: 1 1 0 0 0
Dopadł mnie problem migającej kontrolki świec. Po podpięciu pod kompa wyżej błędy. EGR zdechł, czy dopiero zdycha ?
Wymiana czy da rade czyszczenie ? Można z tym jechać czy nie ? Auto pracuje normalnie ... Do dzisiaj jak zgasiłem auto kontrolka znikała , dzisiaj gaszę , jadę z 200 metrów i wraca
Pomoże ktoś ? Co dalej z tym ?
