Dzisiaj jest 18 lut 2026, 05:41
[2.0 TSI 210KM] Check Engine - 2 błędy
Popielniczka
  • Online: 19h 30m 49s
  • Auto: mk 6
  • Silnik: 2.0 TSI 255km+
Post15 kwie 2014, 12:31
Czy może ktos pomóc takie błędy mi wyskoczyły, wg mnie to dolot, w sobote byl czyszczony, zrobilem na nim 250 km i rano wyskoczył Check Engine.
Kod: Zaznacz cały
Tuesday,15,April,2014,13:27:11:62939
Data version: 20130910
VIN: WVWZZZ1KZBW300291   License Plate: SG4419G
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0050
   Revision: AAH18---    Serial number:
   Coding: 0403000C1C070160
   Shop #: WSC 01357 011 00200
   VCID: E7DDDD17D6988F26B59-80B2
2 Faults Found:
000104 - MAP/MAF <-> Throttle Position Correlation
               P0068 - 000 -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 55503 km
                    Time Indication: 0
                    Date: 2034.14.08
                    Time: 14:27:16
                    RPM: 2033 /min
                    Load: 57.2 %
                    Speed: 82.0 km/h
                    Temperature: 77.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.224 V
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 55533 km
                    Time Indication: 0
                    Date: 2034.14.08
                    Time: 19:32:55
                    RPM: 3411 /min
                    Load: 52.5 %
                    Speed: 137.0 km/h
                    Temperature: 94.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.224 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 057 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2727
   Revision: 05351113    Serial number: 00001103311308
   Coding: 0000020
   VCID: 19392BEFD06C69D673D-804C
No fault code found.
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   VCID: 6ED32833B162DE6E76F-803B
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AE
   Coding: 40180A3A8825F3004088008074000BEC435D0088736D8D60E48000240040
   VCID: 387FCE6B8BA650DE6C3-806D
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 28031  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 060411 05  54  0403
   Coding: 0330AD
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
2 Faults Found:
01500 - Bulb for Fog-Lamps; Right (L23)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 4
                    Fault Frequency: 123
                    Reset counter: 103
                    Mileage: 54765 km
                    Time Indication: 0
                    Date: 2033.14.29
                    Time: 12:58:47
                        Term 15 On
                    Voltage: 12.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01496 - Bulb for Fog-Lamps; Left (L22)
                    Fault Priority: 4
                    Reset counter: 103
                    Mileage: 54765 km
                    Time Indication: 0
                    Date: 2033.14.29
                    Time: 12:58:50
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0012
   Revision: --------    Serial number: 12501106701086
   Coding: 108103
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RA3N0PQ
   Coding: 0000394E
   VCID: 3169F34F60DC81962BD-8064
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME4251545EZZZX
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME5C6B745CZZZD
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3512QSME78261D42ZZZY
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3522QSME42341E25ZZZR
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0080
   Revision: --------    Serial number:  90422KD1001CQ
   Coding: 1892140000
   ROD: EV_SMLSNGKUDS.rod
   VCID: 76E30053C932E6AEBEF-8023
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H06 0010
   Serial number: 0031950
   Coding: 830000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K6 920 881     HW: 5K6 920 881
   Component: KOMBI         H04 0206
   Serial number: 00000000000000
   Coding: 170F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: F2EBBC43255A7A8E127-80A7
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 070411F2003006
   Coding: 350000
   VCID: 306FF64B63D6889E243-8065
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0206
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: EADBA4230D8AB24EAA7-80BF
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7669748955
   Coding: 010000
   VCID: 285F1E2B5B06C05EFC3-807D
1 Fault Found:
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 103
                    Mileage: 55559 km
                    Time Indication: 0
                    Date: 2034.14.09
                    Time: 13:26:14
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2117
   Coding: 0004150
   VCID: 326BFC43ADDABA8E527-8067
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 74     3201
   Revision: 00H20000
   VCID: 3467FA5B57CEB4BE40B-8061
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Coding: 0004406
   VCID: 3365F94752C0B386591-8066
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1442908
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000022
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: RCD510        H16 5026
   Revision: -----13S    Serial number: VWZ4Z3L1124062
   Coding: 0100040004
   VCID: E5C1D71FEC949D36875-80B0
End   ---------------------------------------------------------------------
Popielniczka
  • Auto: mk 6
Re: Check Engine - 2 błędy
Post15 kwie 2014, 14:14
juz naprawione , mozna usunac ;)
jmf
  • Online: 9d 18h 33m 54s
  • Pochwały: 9
  • Silnik: 1.4 TSI 122KM DSG
Post15 kwie 2014, 15:26
Fajnie byłoby napisać, o co chodziło/co pomogło. Może kiedyś komuś ta informacja pomoże...
Popielniczka
  • Auto: mk 6
Post15 kwie 2014, 17:47
Sprawa tak banalna że wolałem nie pisać.
Cały dolot sie poluzował, i zasysał złe powietrze, od nowa zamocowany, skręcony, błedy wykasowane VCDSem.
jazda testowa zrobiona wszystko OK!
