Dzisiaj jest 18 lut 2026, 08:52
[2.0 TDI 140KM] Szarpanie przy 1800-2000 obrotow
xsaren11
  • Online: 6h 24m 3s
Post21 paź 2018, 09:20
Od dluzszego czasu borykam sie z tym problemem ale nikt nie ma pojecia co to.
Obiawy:
- Szarpanie przy 1800-2000 obrotow
- Ostry zapach spalin
Prosilbym o sprawdzenie logow moze ktos z was cos wymysli:
Korekcja wtryskow na zimnym:
10:08:25
IDE00019 Voltage terminal 30 14.640 V
IDE00021 Engine speed 782 /min
IDE00365 Injection amount deviation cylinder 1 0.63 mg/stroke
IDE00366 Injection amount deviation cylinder 2 -0.44 mg/stroke
IDE00367 Injection amount deviation cylinder 3 0.08 mg/stroke
IDE00368 Injection amount deviation cylinder 4 -0.27 mg/stroke
Pozostale:
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HW: 03L 907 309 R
Component: R4 2.0l TDI H23 9978
Revision: 42H23--- Serial number: 00000000000000
Coding: 00190012042400080000
Shop #: WSC 29230 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018 003014
ROD: EV_ECM20TDI01103L906018_VW36.rod
VCID: 67DDD1FA9EACFE7A01-8032
1 Fault Found:
5286 - Throttle Position Sensor (G69)
P0121 00 [096] - Implausible Signal
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 133483 km
Date: 2018.10.19
Time: 18:00:59
Engine speed: 389.00 /min
Normed load value: 100.0 %
Vehicle speed: 0 km/h
Coolant temperature: 78 °C
Intake air temperature: 26 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.280 V
Unlearning counter according OBD: 39
Air mass: actual value (mg/stroke): 473.7 mg/stroke
Throttle valve adapter: specified value: 0.00 %
Throttle valve adapter: actual value: -0.21 %
Throttle valve adapter: offset closed: -12.08 %
Throttle valve adapter: status-Bit 0: 0
Throttle valve adapter: status-Bit 16: 8
Throttle valve adapter: status-Bit 24: 55
Throttle valve adapter: status-Bit 8: 2
Throttle valve adapter: uncond voltage actual value: 933.2 mV
Readiness: 0 0 0 0 0
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 143B400D092A0002280F02E690200042350000
Shop #: WSC 01357 011 00200
VCID: 76E38CBEC10617F28A-8022
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Mileage: 133399 km
Time Indication: 0
Date: 2018.10.17
Time: 17:17:01
Count: 0
Count: 32768
Count: 4608
Count: 397
Count: 51712
Count: 0
Count: 1276
Count: 0
Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000002
VCID: 6ED3A4DEB1562F3242-803A
No fault code found.
Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
Component: BCM PQ35 M 103 0615
Revision: 00103 AD
Coding: 40180A3A8825F3C040080080740081E443510088736D8560648000200040
VCID: 35614BB29C805CEA43-8060
Component: Wischer 14121 26 0512
Coding: 009795
Component: RLS 151210 05 54 0403
Coding: 0330AD
Subsystem 4 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
1 Fault Found:
01598 - Drive Battery Voltage
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 6
Fault Frequency: 25
Reset counter: 6
Mileage: 126319 km
Time Indication: 0
Date: 2018.04.08
Time: 14:07:02
Term 15 On
Voltage: 13.45 V
ON
ON
Term 50 Off
OFF
ON
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 P HW: 3T0 919 475 C
Component: PARKHILFE PLA H08 0116
Revision: -------- Serial number: 13991030602308
Coding: 10800A
VCID: 489F3246FB72D10228-801C
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Serial number: 003G5R01PBNP
Coding: 00003832
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 31697FA260E870CA1F-8064
Crash sensor for side airbag: driver side:
Serial number: 3572MSME7036725AZZZX
Crash sensor for side airbag: front passenger side:
Serial number: 3582MSME32175359ZZZT
Crash sensor for side airbag: rear: driver side:
Serial number: 3512QSME20386F56ZZZ-
Crash sensor for side airbag: rear: passenger side:
Serial number: 3522QSME08337B62ZZZW
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JLD001FA
Coding: 108A140000
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 72EBB0AEA56E0BD2A6-8026
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Serial number: 50000000000000266985
Coding: E20000
Part No SW: 5K0 920 880 A HW: 5K0 920 880 A
Component: KOMBI H03 0206
Coding: 170F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 2C576ED647CA1D222C-8078
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 181210F1001573
Coding: 350002
VCID: 306F7AA663E279C210-8064
Component: IMMO H03 0206
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADBA8CE8DBEC3121E-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669129139
Coding: 020000
VCID: 285F92C65B323102C8-807C
1 Fault Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 7
Mileage: 133499 km
Time Indication: 0
Date: 2018.10.21
Time: 09:58:13
Address 37: Navigation (J794) Labels: 3C0-035-270.clb
Part No SW: 3C0 035 270 B HW: 3C0 035 270
Component: RNS310 H19 0353
Revision: 10000000 Serial number: VWZ1Z2K3897124
Coding: 040004010400000000000000
ASAM Dataset: VW_RNS310 A02007
ROD: N/A
VCID: 1939A7021858988A47-804C
No ASAM data for: "VW_RNS310" (VW36)
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 5K0 959 701 C HW: 5K0 959 701 C
Component: Tuer-SG 009 2119
Coding: 0004278
VCID: 326B70AEADEE4BD266-8066
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 346776B657FA45E274-8060
Part No SW: 5K0 959 702 E HW: 5K0 959 702 E
Component: Tuer-SG 009 2151
Coding: 0004534
VCID: 35614BB25C805CEA43-8060
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 36634CBE418657F24A-8062
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 5N0 035 730 D HW: 5N0 035 730 D
Component: Telefon 009 0511
Revision: -------- Serial number: 35909603085475
Coding: 020000000100000000010000
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_VW32.rod
VCID: 295997C24838080AD7-807C
Krzysztof
szymon
  • Online: 1d 15h 53s
  • Silnik: 2.0 TDI CR CFFB
Re: Szarpanie przy 1800-2000 obrotow
Post06 sty 2019, 16:37
Mam podobne problemy na takim silniku CFFB.
VCDS żadnych błędów wycięty EGR.
Udało się znaleźć rozwiązanie ?
tipmaniak
  • Online: 4h 33m 13s
  • Auto: Vw polo 6R
  • Silnik: CAYB
Post06 sty 2019, 19:51
Witam, ja mam też taki problem ale w silniku 1.6 tdi Cayb 90km. Na 4 i 5 biegu po wciśnięciu gazu do podłogi między 1500-2000 obr. Czuć takie szarpanie.
szymon
Post27 sty 2019, 23:04
Problem usunięty. Winne były świece żarowe, co ciekawe po przyłożeniu napięcia stare grzały. Przypomnę tylko u mnie problem występował na zimnym silniku rano podczas jazdy pod obciążeniem i ustępował po 2-3 km.
Post28 sty 2019, 00:34
szymon pisze:Problem usunięty. Winne były świece żarowe, co ciekawe po przyłożeniu napięcia stare grzały. Przypomnę tylko u mnie problem występował na zimnym silniku rano podczas jazdy pod obciążeniem i ustępował po 2-3 km.
Szkoda ze nie zobaczyłem tematu. Podpowiedział bym. Świece żarowe w CR grzeją impulsowo cały czas do osiągnięcia temperatury silnika . Ma to za zadanie pełne Spale ie mieszanki żeby nie zawalić dpfa i spełniać normy.
