Dzisiaj jest 18 lut 2026, 12:15
Jak odinstalować moduł haka
marwrd
  • Online: 2d 9h 15m
  • Auto: Vw Golf 6 148PS
  • Silnik: 2.0 TDI 110PS CBDC
Post01 paź 2016, 18:51
Witam dziś odpaliłem vcds i po scanie pokazał mi na czerwono takie elementy:
01-Engine - Status Multifunction 0010
09-Cent.Elect. - Status Multifunction 0010
19-Can Gateway - Status Multifunction 0010
69-trailer - status cannotbe reached 1100
Po wejściu w poszczególne błędy wyświtliło :
Saturday,01,October,2016,12:12:20:62939
Address 01: Engine Labels: None
Control Module Part Number: 03L 906 022 HH HW: 03L 906 022 G
Component and/or Version: R4 2,0L EDC G000SG 3004
Software Coding: 0000071
Work Shop Code: WSC 12345 259 82015
VCID: 72EB3C436D5AFA8E927-8027
2 Faults Found:
001025 - EGR System
P0401 - 000 - Insufficient Flow - Intermittent - MIL ON
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 255
Reset counter: 255
Mileage: 143716 km
Time Indication: 0
Date: 2019.14.12
Time: 12:42:48
RPM: 1334 /min
Speed: 12.0 km/h
Voltage: 13.98 V
Load: 14.9 %
Load: 100.0 %
Mass Air / Rev.: 260.0 mg/str
Mass Air / Rev.: 380.0 mg/str
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent - MIL ON
Fault Priority: 2
Fault Frequency: 12
Reset counter: 255
Mileage: 152481 km
Time Indication: 0
Date: 2025.14.10
Time: 14:08:14
RPM: 2231 /min
Speed: 116.0 km/h
Load: 0.0 %
Absolute Pres.: 1938.0 mbar
Absolute Pres.: 1509.6 mbar
Lambda: 100.2 %
Lambda: 31.6 %
Readiness: 1 2 0 0 0
Saturday,01,October,2016,12:18:01:62939
Control Module Part Number: 1K0 937 084 HW: 1K0 937 084
Component and/or Version: BCM PQ35 B 020 0358
Software Coding: 40180A3A9025F3C040080080100000E445010088524D8960648000000000
Work Shop Code: WSC 00028 028 00001
VCID: EBD5A1270A70AB46D11-80BE
4 Faults Found:
02723 - Control Circuit for Power Supply Relay (Terminal 50)
012 - Electrical Fault in Circuit - Intermittent
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 156
Mileage: 151198 km
Time Indication: 0
Date: 2024.14.24
Time: 14:59:47
Term 15 On
Voltage: 12.35 V
OFF
ON
Term 50 On
OFF
OFF
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 233
Mileage: 128176 km
Time Indication: 0
Date: 2008.14.17
Time: 11:11:59
Term 15 Off
Voltage: 12.45 V
OFF
ON
Term 50 Off
OFF
OFF
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 200
Mileage: 138490 km
Time Indication: 0
Date: 2015.14.17
Time: 19:39:38
Term 15 On
Voltage: 10.05 V
ON
ON
Term 50 On
OFF
OFF
Fault Priority: 4
Fault Frequency: 1
Reset counter: 179
Mileage: 143939 km
Time Indication: 0
Date: 2019.14.18
Time: 20:24:08
Term 15 On
Voltage: 14.05 V
ON
ON
Term 50 Off
OFF
OFF
Saturday,01,October,2016,12:20:15:62939
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Control Module Part Number: 1K0 907 530 Q HW: 1K0 907 951
Component and/or Version: J533 Gateway H07 5063
Software Coding: E9807F460002020002
VCID: 3561C75F5CB4ADB6775-8060
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 233
Mileage: 128176 km
Time Indication: 0
Date: 2008.14.17
Time: 11:12:01
nie udało się wejść aby odczytać
NASTEPNIE USUNĄŁEM BŁEDY KTORE DAŁO SIE USUNĄC - następnie pojeździłem inic się nie wyświetliło na liczniku zegarów po ponownym podłączeniu vcds pierwszy błag cyli engine się nie wyświetlił a pozostałe 3 dalej swieciły na czerwono
Czy ktoś jest w stanie powiedzieć o co chodzi bo nie jetem bigły w tej sprawie ???
Re: Kontrolka awari katalizatora 2.0 tdi cr
Post01 paź 2016, 18:59
A masz hak ? Bo to błąd modułu haka.
marwrd
  • Online: 2d 9h 15m
Post01 paź 2016, 19:09
kurde właśnie wpisuje te błędy wgoogle i widz ze błędy 09 i 69 mogą być przyczyną tego ze poprzedni włąsciciel domontował hak do samochodu a jak gdy go kupiłem zdemontowałem cały tył wraz z sterownikiem i wiązka i sprzedałem......
Tylko jeśli te błędy sa z tego czy można to jakoś naprawić bo nie lubie jakcos jest nie tak i swieci na czerwono
-- 01 paź 2016, 19:12 --
tylko z czego to jest???
Post01 paź 2016, 19:14
Tak można, należy odinstalować moduł haka i powinno być w porządku.
marwrd
  • Online: 2d 9h 15m
Post01 paź 2016, 19:33
jarekgk pisze:Tak można, należy odinstalować moduł haka i powinno być w porządku.
Jak tego dokonać??? Może jakiś tutorial szybki opis???
-- 01 paź 2016, 19:36 --
odnośnie błedów
001025 - EGR System
jak teraz czytam problemy użytkowników na forum widze ze spalanie w moim golfie wzrosło o ok 1l/100km
i do tego wydaje mi się ze stracił trochę mocy w dolnym zakresie
Możewarto byłoby przeczyscic egr albo sprawdzić podciśnienia ???
Post01 paź 2016, 20:01
Co do odinstalowania modułu przyczepki to wchodzisz w sterownik w którym jest błąd, wchodzisz w 07 coding i szukasz odpowiedniego bitu, odznaczasz zatwierdzasz i powinno być po błędzie. Natomiast teraz nie pamiętam dokładnie który bit się odznaczało.
marwrd
  • Online: 2d 9h 15m
Post01 paź 2016, 20:07
czyli mam rozumieć ze te dwa błędy
pochodzą od zdemontowanego haka ???
widze tez żę
09-Cent.Elect. - Status Multifunction 0010 pewnie tez jest związany z hakiem
to co mi napisałeś jest dla mnie jasne tylko co dalej z tymi bitami który odznaczyć?
marwrd
  • Online: 2d 9h 15m
Post02 paź 2016, 10:01
Dzis sprobuje cos poradzic z kodowaniem i odinstalowanien tego haka....
Moze jeszczecktos cos poradzi z tymi bledami
001025 - EGR System
mzeberek
  • Online: 20d 9h 52m 26s
  • Silnik: CGGA 1.4 59kW
Re: Jak odinstalować moduł haka
Post02 paź 2016, 19:49
W Gateway masz wskazane jakie są sterowniki zainstalowane w samochodzie. Odznacz tam i powinno być OK
Wysłane z mojego HUAWEI SCL-L21 przy użyciu Tapatalka
Post02 paź 2016, 20:06
marwrd pisze:Dzis sprobuje cos poradzic z kodowaniem i odinstalowanien tego haka....
001025 - EGR System
Ty to nieszczęśliwy człowiek jesteś.
Wchodzisz w gateway i odznacza sz hak. Potem w bcm także. Jeżeli masz czujniki parkowania to tam także się odznacza ale nie wkleileś auto skanu wiec to wróżenie . W silniku to już są nazwa wskazuje alw jak by były dalej problemy ze zrozumieniem to np ctrl+c i ctrl +v i w google i tadammmmm
Sorki za sarkazm ale jak nie chcesz zapłacić komuś za usługę to poczytaj leniu i będziesz umiał diagnozować
