Dzisiaj jest 18 lut 2026, 06:48
Golf6 2.0 tdi CBDC (110KM) - EGR, DPF
exolive
  • Online: 1h 25s
  • Silnik: 2.0 TDI CBDC
Post25 sty 2016, 21:43
cześć,
nie jestem Polakiem i nie mowie po Polsku :( ale bardzo rozumiem.
I would like ask questions but in English if you don't mind.
So, I live in Krakow and I have the golf 6 like in topic theme and I want to delete EGR and DPF filter. Also I want to install cooler from audi S3 and quite bigger turbo from 170KM and add REVO chip stage 2 - but that is for another one topic.
Question are:
1 What Polish government does with these modifications, will they fine me?
2 How will I pass technical review in Polish (badanie techniczne)?
3 Who can advise me and do this work in Krakow (I need only first step - block EGR and remove DPF)?
thanks for answers.
feel free and write in Polish, I understand.
Re: Golf6 2.0 tdi CBDC (110KM) - EGR, DPF
Post25 sty 2016, 23:12
It's not a problem for our government what You do with your car and You pass technical review.
Will be problem if you change your engine on petrol... so you can do what you want - good luck ; )
With egr and DPF ask here ( http://www.mickey-garage.com/ ) maybe they can help You because it's in Kraków
exolive
  • Online: 1h 25s
Post26 sty 2016, 09:33
In march I have to pass technical inspection, as I understood inspector does not care about what have to be installed in my car. Am I right?
Will they check some measure of toxic exhaust or just if DPF filter is present?
Probably they know that cars from 2006 should be with DPF and can rise a problem for me (return it back or pay fine)
lkgh
  • Online: 12d 6h 55m 49s
  • Silnik: 2.0 TDI 175koni
Post26 sty 2016, 13:10
Based on my experience.....they don't give a fuck. As long horn, all lights are working, no slack in the suspension or leak is detected....you will be ok
Post26 sty 2016, 13:19
Well said :-) they dont care at all. And if its done properly they will not even notice.
Post01 lut 2016, 22:33
I have question about this engine... can I modify only map engine from 110KM to 160KM? Engine will withstand this without a problem?
exolive
  • Online: 1h 25s
Post23 mar 2016, 07:11
true :) I have new map 166KM and 400Nm :D
TuneFORCE
  • Online: 19h 32m 2s
  • Auto: Golf
  • Silnik: CDLF
Post06 maja 2016, 20:35
Call me on Monday I will explain u "how it work" ;)
Wróć do Tuning mechaniczny
