Dzisiaj jest 18 lut 2026, 08:17
Upgrade mk70 abs to mk60ec abs
HKNNET
  • Online: 12d 5h 35m 50s
Post16 maja 2021, 14:39
Hello all,
I am Hakan. I have mk6 golf and Im thinking upgrade abs pump-module for pla and another modifications. I bought 379cc module but my abs pump(379ak) has 26pins but cc module has 47 pins. I am researching for convert with elsa but I couldn't get any clear information. Do you know a source or schema I can use?
I shared abs logs.
I am waiting your help.
Thanks
Kod: Zaznacz cały
 Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0105
   Revision: 00H35001
   Coding: 0017665
   Shop #: WSC 00028 028 00001
   VCID: 7BDAACF03A7B469288-802E
poaa1hd
  • Online: 3d 1h 6m 39s
  • Auto: Touran
  • Silnik: BLS
Re: Upgrade mk70 abs to mk60ec abs
Post23 maja 2021, 22:46
mk6-f70/wymiana-pompy-abs-asr-na-abs-asr-eds-hds-esp-t6509.html here You have everything You have to know. I hope google translate will be good enough to help You translate all info.
Wróć do Retrofitting
cron
