Dzisiaj jest 27 kwie 2024, 03:07
Forum miłośników Volkswagen Golf
Przejdź do: Indeks witryny » GOLF MK6 » Pytania / Porady » Multimedia
Wednesday,23,May,2018,12:15:35:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WVWZZZ3CZ9E545613 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 42 44 46 4F 52 53 55 56 5C
62 72 76 77
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
76-Park Assist -- Status: Cannot be reached 1100
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 QF HW: 03L 907 309
Component: R4 2,0L EDC G000SG 3735
Revision: 13H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 84224 792 591430
VCID: 79FF9BBF305B80D6DC3-802C
2 Faults Found:
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 119149 km
Time Indication: 0
Date: 2023.14.30
Time: 17:40:48
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.01 V
Lambda: 81.3 %
Lambda: -20.5 %
Bin. Bits: 00001110
Voltage: 1.976 V
000289 - Throttle Position Sensor (G69)
P0121 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 119149 km
Time Indication: 0
Date: 2023.14.30
Time: 18:23:39
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.40 V
Lambda: 11.0 %
Lambda: -3.2 %
Bin. Bits: 00001110
Voltage: 0.988 V
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 T HW: 3C0 614 109 T
Component: J104 C4 440 V2 0013
Revision: --025--- Serial number: 00000786419766
Coding: 0002346
Shop #: WSC 05311 000 00000
VCID: 2F6B65E7BE9F9E66327-807A
No fault code found.
Part No SW: 5K0 907 044 AK HW: 5K0 907 044 AK
Component: Climatronic 130 0303
Revision: 00002001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 74E1AA8BDF39FDBE8F5-8021
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000009101517
Coding: E3E28F8B00041A0047978F0017000000000BFB4764400165170000000000
Shop #: WSC 05124 000 00000
VCID: 3363699752B7BA8656F-8066
Subsystem 1 - Part No: 3C8 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 041108 022 0602
Coding: 00046997
Shop #: WSC 05124
Component: RLS 011208 054 0402
Coding: 00471277
Shop #: WSC 05124
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 L HW: 1T0 919 475
Component: PARKHILFE PLA H07 0021
Revision: -------- Serial number: 06530832404465
Coding: 100007
VCID: 44813A4BC7190D3EFF5-8011
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 3C0 907 376 HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0069
Revision: 00000000 Serial number: 20110801090002
Coding: 010180
Shop #: WSC 05314 000 00000
VCID: E6C540C311E59F2E811-80B3
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__304 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPP67AHT
Coding: 0012340
VCID: 3B7341B77AE772C68EF-806E
Subsystem 1 - Serial number: 6333FTS655182968
Subsystem 2 - Serial number: 6343FTS615430690
Subsystem 3 - Serial number: 6353ETS61MAVVVNJ
Subsystem 4 - Serial number: 6363ETS6AAD0V5KR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0030
Revision: 00032000 Serial number: 3C5953507CQ
Coding: 0200511
VCID: 74E1AA8B1739FDBE8F5-8021
Subsystem 1 - Part No: 3C8 959 537 B
Component: E221__MFL-TAP H4˙ 0021
Coding: 00000226
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 870 C HW: 3C8 920 870 C
Component: KOMBI H05 0107
Coding: 140F00
Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 2B5371F74287E2461EF-807E
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 J HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 2900R08B058153
Coding: F9A97F0E00060B009002
Shop #: WSC 05314 123 12345
VCID: 28598EFB9B71C95EF3D-807D
2 Faults Found:
00469 - Infotainment Databus in Single Wire Operation
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:10:26
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:10:28
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 799 H HW: 3C0 959 799 H
Component: IMMO 070 0383
Revision: 00070000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 3E7548A369F567EEA91-806B
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1533
Revision: 71009005 Serial number: 00000548388926
Coding: 0004279
VCID: 4089365B1301111EDBD-8015
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 J HW: 5N1 909 148 F
Component: J500__APA-BS KL.071 0502
Revision: 1AH02240 Serial number: 00083220212802
Coding: 0000258
Shop #: WSC 06760 995 88939
VCID: 397F5BBF70DB40D69C3-806C
Address 46: Central Conv. Labels: 3C0-959-799-46.clb
Component: 09 KESSY PQ46 R 070 0231
Coding: 00910A0001C60E763604941570004F0B607C0103240498
Shop #: WSC 05311 123 12345
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
00192 - Rear Left Door Handle Touch Sensor (G417)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:10:23
Address 4F: Centr. Electr. II (J533_) Labels: 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 3C0 907 951
Revision: -------- Serial number: 2900R08B058153
Coding: 01030100
Subsystem 1 - Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245/J878 H04 0054
Coding: 000006
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1533
Revision: 71009005 Serial number: 00000759489008
Coding: 0004278
VCID: 418F335F180B1816D43-8014
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000208036
Coding: 0000057
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0136
Revision: 00H04000 Serial number:
Coding: 3493064
VCID: 34616A8B57B9BDBE4F5-8061
Subsystem 1 - Part No: 1K0 941 329
Component: AFS-Lst.-Modul l 0003
Coding: 00000053
Subsystem 2 - Part No: 1K0 941 329
Component: AFS-Lst.-Modul r 0003
Coding: 00000053
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0130
Revision: 00000001 Serial number: VWZ1Z3H3388065
Coding: 0500040004
VCID: E5C747CFECE3943688B-80B0
Address 5C: Lane Maintain. Labels: 3C0-907-217.clb
Part No SW: 3C0 907 217 A HW: 4E0 907 217 C
Component: J759 HCA 0130
Revision: 00H07003 Serial number: 300208B1000042
Coding: 0030002
VCID: 214F93DFF84B3816B43-8074
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q
Component: J388 TUER-SG HL 0309
Revision: 43004101 Serial number: 00000000740671
Coding: 0000144
VCID: 316F639FA8AB8896243-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 3C8 959 704 B HW: 1K0 959 794 Q
Component: J388 TUER-SG HR 0309
Revision: 43004101 Serial number: 00000000723963
Coding: 0000144
VCID: 326D6C93ADADB38E5D9-8067
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 C HW: 3C8 035 730 C
Component: Telefon 012 0822
Revision: -------- Serial number: 35909603386825
Coding: 020104010100110000000000
Shop #: WSC 85046 004 02308
ASAM Dataset: EV_UHVPremi A02705
ROD: EV_UHVPremi_SE36.rod
VCID: 234399D72A572A06A6F-8076
1 Fault Found:
9455635 - Telephone Microphone
B1048 13 [009] - Open Circuit
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Date: 2088.14.11
Time: 12:10:23
End ---------------------------------------------------------------------
62 72 76 77
Coding: 0000072
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 119149 km
Time Indication: 0
Date: 2023.14.30
Time: 17:40:48
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.01 V
Lambda: 81.3 %
Lambda: -20.5 %
Bin. Bits: 00001110
Voltage: 1.976 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 119149 km
Time Indication: 0
Date: 2023.14.30
Time: 18:23:39
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.40 V
Lambda: 11.0 %
Lambda: -3.2 %
Bin. Bits: 00001110
Voltage: 0.988 V
Coding: 0002346
Revision: 00002001
Coding: 0000000000
Coding: 00046997
Shop #: WSC 05124
Coding: 00471277
Shop #: WSC 05124
Coding: 100007
Coding: 010180
Coding: 0012340
Coding: 0200511
Coding: 00000226
Shop #: WSC 00000
Coding: 140F00
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:10:26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:10:28
Coding: 0004279
Coding: 0000258
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:10:23
Coding: 01030100
Coding: 000006
Coding: 0004278
Coding: 0000057
Coding: 3493064
Coding: 00000053
Coding: 00000053
Coding: 0500040004
Coding: 0030002
Coding: 0000144
Coding: 0000144
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Date: 2088.14.11
Time: 12:10:23
Wednesday,23,May,2018,16:27:37:33490
Address 77: Telephone Labels: 3C8-035-730-A.clb
Control Module Part Number: 3C8 035 730 C HW: 3C8 035 730 C
Component and/or Version: Telefon 012 0822
Software Coding: 020104010100110000000000
Work Shop Code: WSC 85046 004 02308
ASAM Dataset: EV_UHVPremi A02705 (VW46)
4 Faults Found:
9457427 - Left audio channel for speech/telephone
B104F 13 [008] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 244
Mileage: 119166 km
Date: 2088.14.11
Time: 16:13:25
9457171 - Right audio channel for speech/telephone
B104E 13 [008] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 244
Mileage: 119166 km
Date: 2088.14.11
Time: 16:13:25
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Date: 2088.14.11
Time: 16:11:15
0022 - Radio
U1066 00 [008] - No Communication
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 244
Mileage: 119166 km
Date: 2088.14.11
Time: 16:13:29
Wednesday,23,May,2018,16:35:28:33490
62 72 76 77
56-Radio -- Status: Malfunction 1010
77-Telephone -- Status: Malfunction 1010
Coding: 0000072
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 119149 km
Time Indication: 0
Date: 2023.14.30
Time: 17:40:48
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.01 V
Lambda: 81.3 %
Lambda: -20.5 %
Bin. Bits: 00001110
Voltage: 1.976 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 119149 km
Time Indication: 0
Date: 2023.14.30
Time: 18:23:39
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.40 V
Lambda: 11.0 %
Lambda: -3.2 %
Bin. Bits: 00001110
Voltage: 0.988 V
Coding: 0002346
Revision: 00002001
Coding: 0000000000
Coding: 00046997
Shop #: WSC 05124
Coding: 00471277
Shop #: WSC 05124
Coding: 100007
Coding: 010180
Coding: 0012340
Coding: 0200511
Coding: 00000226
Shop #: WSC 00000
Coding: 140F00
4 Faults Found:
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 24
Reset counter: 244
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:10:26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:10:28
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 244
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:32:45
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 244
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 13:49:22
Coding: 0004279
Coding: 0000258
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:10:23
Coding: 01030100
Coding: 000006
Coding: 0000057
Coding: 3493064
Coding: 00000053
Coding: 00000053
Coding: 0500040004
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 244
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 15:18:32
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:36:36
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Time Indication: 0
Date: 2024.14.11
Time: 12:36:36
Coding: 0030002
Coding: 0000144
Coding: 0000144
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 244
Mileage: 119166 km
Date: 2088.14.11
Time: 16:13:25
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 244
Mileage: 119166 km
Date: 2088.14.11
Time: 16:13:25
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 204
Mileage: 119166 km
Date: 2088.14.11
Time: 16:11:15
0022 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 244
Mileage: 119166 km
Date: 2088.14.11
Time: 16:13:29
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
Style we_universal created by weeb. phpBB SEO
Kontakt webmaster@golf6.pl
