marrcin pisze:a od kiedy zmienili ten nastawnik?
Od 1 lipca 2010 r.
-- 23 lis 2013, 23:40 --
sebkoch pisze:
W jaki sposób to zdiagnozowałeś?
Zauważyłem rozchwianie obrotów na biegu jałowym - zmieniały się w przedziale 600-900.
Następnie VCDS i wynik:
000010 - Camshaft Positioner (Bank 1 Intake)
P000A - 000 - Slow Response - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 97669 km
Time Indication: 0
Date: 2007.14.25
Time: 12:10:04
Freeze Frame:
RPM: 1814 /min
Load: 10.6 %
Speed: 41.0 km/h
Temperature: 90.0°C
Temperature: 36.0°C
Absolute Pres.: 930.0 mbar
Voltage: 14.097 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 97670 km
Time Indication: 0
Date: 2007.14.25
Time: 12:12:45
Freeze Frame:
RPM: 586 /min
Load: 13.7 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 34.0°C
Voltage: 13.208 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 97670 km
Time Indication: 0
Date: 2007.14.25
Time: 12:12:45
Freeze Frame:
RPM: 586 /min
Load: 13.7 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 34.0°C
Voltage: 13.208 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 97670 km
Time Indication: 0
Date: 2007.14.25
Time: 12:12:45
Freeze Frame:
RPM: 586 /min
Load: 13.7 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 34.0°C
Voltage: 13.208 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 97670 km
Time Indication: 0
Date: 2007.14.25
Time: 12:16:58
Freeze Frame:
RPM: 453 /min
Load: 43.1 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 35.0°C
Voltage: 12.954 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 97670 km
Time Indication: 0
Date: 2007.14.25
Time: 12:16:58
Freeze Frame:
RPM: 453 /min
Load: 43.1 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 35.0°C
Voltage: 12.954 V
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 000 - Incorrect Correlation
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 97760 km
Time Indication: 0
Date: 2007.14.25
Time: 20:30:48
Freeze Frame:
RPM: 661 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 54.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.462 V
Ross-Tech Wiki:
17748/P1340/004928 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
Possible Causes
Timing Belt/Chain incorrectly installed
Timing Chain probably lengthened
Camshaft Position Sensor (G40) faulty
Engine Speed Sensor (G28) faulty
Possible Solutions
Check Timing Belt/Chain installation
Use Measuring Value Blocks (MVB) to Check Timing Chain
Check/Replace Camshaft Position Sensor (G40)
Check/Replace Engine Speed Sensor (G28)
