Dzisiaj jest 26 kwie 2024, 16:45
Nie działa ESP
mclukas
  • Online: 1d 11h 32m 1s
  • Auto: golf 6
Nie działa ESP
Post27 paź 2014, 15:57
Witam wszystkich siedziałem ostatnio w aucie i włączyłem test abs :/ udało mi się go jakoś przeprowadzić ale nadal nie działa mi ESP ...
oto moje błędy :
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 159137 km
Time Indication: 0
Date: 2122.14.18
Time: 19:27:55
Freeze Frame:
Count: 3
Count: 2
Count: 4096
Count: 295
Count: 43264
Count: 0
Count: 0
Count: 0
01279 - Longitudinal Acceleration Sensor (G251)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 1048575 km
Time Indication: 0
Date: 2122.14.18
Time: 19:30:53
Freeze Frame:
Count: 7
Count: 2
Count: 4096
Count: 212
Count: 43520
Count: 0
Count: 0
Count: 0
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 1048575 km
Time Indication: 0
Date: 2122.14.18
Time: 19:30:53
Freeze Frame:
Count: 7
Count: 2
Count: 4096
Count: 211
Count: 43520
Count: 0
Count: 0
Count: 0
02085 - Incorrect Control Module Installed
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 1048575 km
Time Indication: 0
Date: 2122.14.18
Time: 19:30:53
Freeze Frame:
Count: 7
Count: 2
Count: 4096
Count: 204
Count: 43520
Count: 0
Count: 0
Count: 0
01486 - System Function Test Activated <----- to nie aktualne
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 1048575 km
Time Indication: 0
Date: 2122.14.18
Time: 19:30:53
Freeze Frame:
Count: 7
Count: 2
Count: 4096
Count: 320
Count: 43520
Count: 0
Count: 0
Count: 0
1 6 D
  • Online: 34d 18h 29m 3s
  • Auto: Scirocco+Golf
  • Silnik: SB+CBDB
Re: błąd ESP
Post27 paź 2014, 16:55
Daj fragment skanu z kodowaniem ABSu i numerem pompy, wygląda że musisz zrobić adaptację G85 i chyba pompa nie obsługuje Hill Holda a o zakodowałeś.
mclukas
  • Auto: golf 6
Re: błąd ESP
Post28 paź 2014, 15:23
już wszystko rozpracowałem :) dzięki za odpowiedz
pozdrawiam
  • Online: 90d 14h 52s
Re: błąd ESP
Post28 paź 2014, 20:34
mclukas pisze:już wszystko rozpracowałem :) dzięki za odpowiedz
pozdrawiam
Jak już rozpracowałeś i problem rozwiązany to mile widziane było by dokładne opisanie rozwiązanie problemu.
Będzie to przydatne dla potomnych :D z podobnym problemem co Twój.
mclukas
  • Auto: golf 6
Re: błąd ESP
Post12 lis 2014, 18:11
Wyłączenie Hill Hold-a i przeprowadzenie adaptacji czujnika G251 i G85 :) wszystko w opcji ABS w vcds
Użytkownicy przeglądający to forum: Bing [Bot] i 5 gości
