Dzisiaj jest 26 sty 2020, 00:38
[ALL] VCDS - co ten błąd oznacza / analiza błędów
yox
  • Online: 8d 15h 49m 44s
  • Pochwały: 17
  • Ostrzeżenia: 2
  • Auto: VW Touran 1T2
  • Silnik: BXE 1.9 TDI
Re: VCDS - co ten błąd oznacza / analiza błędów
Post25 lis 2018, 17:28
... wszystko fajnie ale czy tak wygląda wg Ciebie autoscan ?
  • Online: 16d 17h 35m 28s
Post25 lis 2018, 18:33
Sunday,25,November,2018,16:59:42:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 20 22 25 42 44 46 47 52 55
5F 65 6C
VIN: WVWZZZ1KZAP019770 Mileage: 5950km-3697miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
14-Susp. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
47-Sound System -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 CB HW:
Component: MOTRONIC ME7.1.1G02 5604
Revision: 00000000 Serial number: XXXXXXXXXXXXXX
Coding: 0000178
Shop #: WSC 00000 000 00000
VCID: 4D91DF36D4D1182E2A-8018
No fault code found.
Readiness: 0010 0101
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 046 D HW: 02E 927 770 AD
Component: GSG DSG 0606
Revision: 04202624 Serial number: 00001204141179
Coding: 0000020
Shop #: WSC 00011 888 06946
VCID: 183F7E622B93AD8649-804C
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 143B600D09230003281206EB90190041A1095051
Shop #: WSC 33361 790 00076
VCID: 7EF348FAE9F773B6E3-802A
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 3AA 907 044 BD HW: 3AA 907 044 BD
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 001800C002
Shop #: WSC 00040 040 00015
VCID: 73E569CEDAB52EDE9C-8026
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 1K8 919 475 D HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0480
Revision: -------- Serial number: 39411425000756
Coding: 0031161011
Shop #: WSC 00567 048 00001
ASAM Dataset: EV_EPHVA2CVW364GP00 001010
ROD: EV_EPHVA2CVW364GP00.rod
VCID: 3B7581EEB265A69E84-806E
1 Fault Found:
12715520 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 146
Mileage: 5924 km
Date: 2018.11.25
Time: 13:21:05
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0070
Revision: 00000000 Serial number: 15060900470002
Coding: 000180
Shop #: WSC 00028 028 00001
VCID: 275D4D9E56ED127EF0-8072
2 Faults Found:
03262 - Comfort Restriction
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 5
Reset counter: 147
Mileage: 5924 km
Time Indication: 0
Date: 2018.11.25
Time: 13:21:48
Freeze Frame:
Error Code: 2
Bin. Bits: 00000000
00774 - Level Control System Sensor; Rear Left (G76)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Mileage: 5924 km
Time Indication: 0
Date: 2018.11.25
Time: 13:21:48
Freeze Frame:
Bin. Bits: 01000000 00000000
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 035 0604
Serial number: 003C2D0D118A
Coding: 00003139
Shop #: WSC 00028 790 00306
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 77FD5DDECECD42FEA0-8022
Component: S.Sens.Fahr.V U01 ----
Serial number: 4B356249ZZZZZZZZZZZZ
Crash sensor for side airbag: front passenger side:
Component: S.Sens.Beif.V U01 ----
Serial number: 0B327547ZZZZZZZZZZZZ
Crash sensor for side airbag: rear: driver side:
Serial number: 2435302EZZZZZZZZZZZZ
Crash sensor for side airbag: rear: passenger side:
Serial number: 3E322E52ZZZZZZZZZZZZ
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110516101235
Coding: 309A260000
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DF14FF6ECF168AEFA-8028
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 830000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 1K8 920 885 J HW: 1K8 920 885 J
Component: KOMBI H02 1104
Serial number: 00000000000000
Coding: 110F010000
Shop #: WSC 01342 020 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 3E7388FAA177B3B6A3-806A
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BG HW: 7N0 907 530 AN
Component: J533 Gateway H56 1671
Revision: H56 Serial number: 130114F2001525
Coding: 350020
VCID: 76E350DAC1C73BF6BB-8022
1 Fault Found:
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 5940 km
Time Indication: 0
Date: 2018.11.25
Time: 14:33:13
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 5K0 857 511 B HW: 8P0 857 511 C
Component: FLA H04 0012
Revision: AA001002
Coding: 0201906B74745D545420363E00
VCID: 2D51BFB67411382E0A-8078
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554
Component: HALDEX 4Motion 0101
Coding: 0000001
VCID: 6ADB74AA457FEF162F-803E
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Component: IMMO H02 1104
Serial number:
Coding: 000000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
VCID: 6ADB74AA8D7FEF162F-803E
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0005056810
Coding: 021077
Shop #: WSC 05311 115 08193
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
VCID: 356197D6944170EE72-8060
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 174 2901
Revision: 00H15000
VCID: 2F6DA5BEBE1D4A3E38-807A
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System (R12) Labels: None
Part No HW: 5K0 035 456
Component: KonzernAmp 8K H06 0316
Revision: -------- Serial number: BP218198597464
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 55A13756340150EE92-8000
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 5K0 959 702 E HW: 5K0 959 702 E
Component: Tuer-SG 009 2121
Coding: 0004470
Shop #: WSC 00110 259 88393
VCID: 356197D65C4170EE72-8060
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1444956
Shop #: WSC 30791 001 1048576
VCID: 3467AAD2573B69E645-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 D HW: 5C0 035 680 D
Component: MU-S-N-ER H31 0363
Serial number: VWZAZ2S5278614
Coding: 02630401AA00000011110003000808001F0100C400200101CF
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 224B5C8A35CFF756A7-8076
Data medium:
Subsystem 1 - Part No SW: 3G0 919 866 BJ HW: -----------
Component: ECE1 2018 --- 0915
Serial number: --------------------
1 Fault Found:
6714 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 5924 km
Date: 2018.11.25
Time: 13:44:52
Voltage terminal 30: 13.8 V
Network diagnosis-Status: Enabled
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 HW: 3AA 907 273
Component: RDKBERU30 H06 0007
Serial number: 10000000003247
ASAM Dataset: EV_RDKBERU30 003010
ROD: EV_RDKBERU30_003.rod
VCID: 71E963C6A0A91CCE6E-8024
1 Fault Found:
12656671 - No Communication with Diagnostic Gateway
U0146 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 187
Mileage: 5957 km
Date: 2000.00.00
Time: 00:00:00
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Coding: 016404016201000700
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
VCID: 306FA6C26B2355C621-8064
2 Faults Found:
10489856 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Mileage: 5923 km
Date: 2018.11.25
Time: 13:17:10
passive
9683731 - External Trigger/Activation
B13C3 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 5924 km
Date: 2018.11.25
Time: 13:26:41
active: waiting for return message
End-------------------------(Elapsed Time: 03:32)--------------------------
yox
  • Pochwały: 17
  • Ostrzeżenia: 2
Post25 lis 2018, 19:04
... ok wiec tak: masz navi ma zegarach ? ;)
1. kodowanie gateway: 356032
2. kodowanie kamery (6C): 011308010201000700
... narazie tak zakoduj, wykasuj błędy i zobacz co zostanie
... sprawdz czy znaczek/mechanizm otwierania/zamykania kamerki dziala prawidłowo :)
Post26 lis 2018, 19:50
Zakodowaniem zgodnie z Twoimi wytycznymi.
Efekt widoczny na video.
Jest małe ale :) obraz z kamery nie wyłącza się po zamknięciu znaczka tylnej klapy.
https://youtu.be/gw7XTqiBb7I
Błąd z którym borykałem się w w/w postach pojawia się po zakodowaniu bitu 6.
yox
  • Pochwały: 17
  • Ostrzeżenia: 2
Post26 lis 2018, 22:03
... jest ok ;) tak własnie działa kamerka na DM (ale jeszce jutro sprawdze u siebie) kamerka wyłaczy sie jak pojedziesz do przodu i przekorczysz 15km/h, co do błedu to pamietaj, ze te sterowniki były montowane w Sharan, Tiguan a więc w "klamce" stąd byc może błąd. Jesli Ci to nie odpowiada to pokombinuj w adaptacjach PLA, tam jest rodzaj wyswietlania "automaic" , "rear view camera" i jakoś podobnie ;) reszta ok ?
-- 26 lis 2018, 22:21 --
... sprawdził bym jeszcze podłaczenie samego znaczka w ELSA ;) jak idzie np w Golf 7 ?
Post28 lis 2018, 14:46
Resta jest super ;)
Schematu golfa 7 nie sprawdzałem
WuBu
  • Online: 13d 9h 33m 14s
  • Auto: VW Golf VII GTD
  • Silnik: CUNA 184 KM TDi
Post28 lis 2018, 17:20
Ciesze się, że Ci sie udało. :pub:
yox
  • Pochwały: 17
  • Ostrzeżenia: 2
Post28 lis 2018, 18:05
... wiec posprawdzaj ;) bo teraz kamerka i "znaczek" "zyja" własnym zyciem ;) dlatego jest bład w kamerce po zakodowaniu, skoro jest odp. bit to byc może moduł kamerki steruje "znaczkiem" i właśnie do niego, zamiast do wstecznego nalezałoby go podłączyć ? :) ... szukaj w ELSA...
fazer
  • Online: 6d 14h 21m 3s
  • Silnik: 1.4 TSI CAXA
Post09 gru 2018, 09:20
Potrzebuje pomocy z jednym błędem :
Kod: Zaznacz cały
Adres 09: Centr.zesp.elektr. (J519)       Plik etykiet:. AKP\1K0-937-08x-09.clb
   Oznaczenie elementu SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Komponent: BCM PQ35  M   103 0575
   Weryfikacja: 00103 AG
   Kodowanie: 40180A3A98251AC040080080240081E443510088536D8960648000200000
   VCID: 306E285C632352C621-8064
   Podsystem 1 - Oznaczenie elementu: 1K1 955 119 F  Plik etykiet: 1KX-955-119.CLB
   Komponent: Wischer 07051  23  0512
   Kodowanie: 009795
   Podsystem 2 - Oznaczenie elementu: 1K0 955 559 AH  Plik etykiet: 1K0-955-559-AG.CLB
   Komponent: RLS 150510 05  54  0403
   Kodowanie: 0330AD
Znaleziono 1 błąd:
00907 - Interwencja układu zarządzania obciążeniem
            000 - -
             Ramka zamrożona:
                    Stan błędu: 01100000
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Wew.licznik błędów: 139
                    Przebieg: 168799 km
                    Wskaźnik czasu: 0
                    Data: 2013.04.30
                    Czas: 14:12:47
             Ramka zamrożona:
                        zacisk 15 ZAŁ
                    Napięcie: 11.70 V
                        ON
                        ON
                        zacisk 50 WYŁ
                        OFF
                        OFF
Post09 gru 2018, 09:22
Nie miałeś czasem za małego napięcia akumulatora ?
fazer
Post09 gru 2018, 09:40
witam
No właśnie nie wiem ,bo w czasie jazdy nagle przygasły zegary .
Podłączyłem pod kompa i taki błąd ,zmierzę napięcie na akumulatorze w spoczynku i po odpaleniu .
Dzięki i pozdrawiam
A-R-T-U-R
  • Online: 14d 7h 55m 24s
  • Auto: Golf VI Match
  • Silnik: CAXA 1.4 TSI
Post09 gru 2018, 11:15
Moze alternator daje znac o sobie
był mk5, jest mk6 1.4 TSI
fazer
Post09 gru 2018, 11:40
A-R-T-U-R pisze:Moze alternator daje znac o sobie
Witaj
Oby chociaż zimę przetrzymać. ,na wiosnę planuję kupić używany i powymieniac lozyska ,szczotki i niech leży w zapasie [WHITE SMILING FACE]
Wysłane z mojego SM-J320FN przy użyciu Tapatalka
Post09 gru 2018, 11:42
Kup nowy będziesz miał gwarancje i spokoj.
kosot
  • Online: 1h 22m 7s
  • Auto: leon
  • Silnik: cayc
Post05 sty 2019, 15:41
Witam, wywaliło mi błąd 14359, a mój VCDS nie rozpoznaje go. Co może oznaczać?
Z góry dzięki za pomoc.
Post05 sty 2019, 15:43
Wrzuć scana lub printscreena tego błędu.
kosot
  • Online: 1h 22m 7s
  • Auto: leon
  • Silnik: cayc
Post05 sty 2019, 16:08
przepisane ze zdjęcia:
" No ASAM data for: "EV_ECM16TDI02103L906023LF" (SE35)
1 Fault Found:
14359-ROD-Unknown Error Code
Freeze Frame:
Fault Status: 0000001
Fault Priority: 2
Fault Frequency : 4
Mileage: 168703 km
Date: 2074.14.22
Time : 19:06:19
dodam też że mam do wymiany termostat, miga kontrolka świec , i świeci kontrolka DPF-a
Post26 sty 2019, 20:56
Koledzy pierwszy raz spotykam się z czym takim ze nie mogę usunąć błędy które wcześniej usuwałem.
Wyglada to tak jak na foto i postara się załączyć video może coś pomożecie bo zablokowało mi webasto :)
https://www.youtube.com/watch?v=OBsxyjJHpEY&feature=share
ObrazekObrazekObrazekObrazek
Muti
  • Online: 19d 11h 57m 5s
  • Pochwały: 15
  • Auto: MK7.5 R
  • Silnik: 2.O TSI DJHA
Post26 sty 2019, 21:03
Webasto zablokowane.
Jest forum tourana jak odblokować. Z tego co pamiętam w adaptacjach w kanale 42 zapisać 1 i wtedy możesz skasować.
  • Online: 38d 2h 38m 7s
  • Ostrzeżenia: 3
Post26 sty 2019, 21:07
Brak płomienia . Widocznie cos sie stalo bo ze swiecą albo paliwem. Piec sie zablokowal po kilkukrotniej nie udanej próbie uruchomienia webasto. Musisz wejść w adaptacje i odblokować pięć. Wtedy skasować błędy i ewentualnie bloki mierzone sprawdzić co nie działa.
Post26 sty 2019, 21:09
Dzięki chłopaki [THUMBS UP SIGN] jutro to ogarnę. Nagram video odblokowania dla potomnych ;)
kosot
  • Online: 1h 22m 7s
  • Auto: leon
  • Silnik: cayc
Post01 lut 2019, 15:15
odnośnie tego 14359 to jest to czujnik temp. spalin nr. 3 ( gdyby ktoś szukał) . Wszystko pogasło i dpf się wypalił. Jest ok
Post05 maja 2019, 15:27
Czy ktoś miał podobny błąd ?
Z tego co sprawdziłem jest to czujnik położenia pedału gazu G79. Domyślam się ze przyczyna może być w pedale gazy czy w przepustnicy ?
Poproszę o rozwiniecie problemu błędu i ew. o poprawę jeśli jestem w błędzie.
molnar
  • Online: 31m 28s
  • Silnik: TSI
Post09 lip 2019, 15:42
Koledzy ktos pomoze wykonac kalibracje kamery i co trzeba wpisac bo za cholere nie moge sobie w odisie poradzic
Jest to modul 7N0 901 441b wiec ten nowy - w starym przeba bylo podac security access a w tym nie wiem czy musze czy tez nie . Bawie sie z tym juz kilka godzin i nie mam pojecia. Moze ktos kalibrowal i pomoze. Kamera jest tylko jedna cofania - nie ma bocznych
ALF
  • Online: 7d 15h 4m 45s
  • Auto: Touran 5T
  • Silnik: 20tdi
Użytkownicy przeglądający to forum: Bing [Bot] i 4 gości
