Dzisiaj jest 26 kwie 2024, 00:53
Błąd 01134 a brak alarmu ????
Piaseczeq
  • Online: 1d 14h 5m 5s
  • Auto: MK6 GTI DSG
  • Silnik: CCZB
Post06 lut 2018, 15:47
A więc, wyskoczył mi dzisiaj błąd 01134 - Alarm Horn (H12), pacjent to golf 6 GTI 2010r. Z kodów wyposarzenia wychodzi że nie mam alarmu xD
B0A Component parts set without country-specific design requirement
CG6 Alloy wheels 7.5J x 17
G1A 6-speed automatic transmission
H6L Tires 225/45 R17 91W
J1D Battery 380 A (72 Ah)
D2D 4-cyl. SI engine 2.0 l/155 kW 16V turbo FSI, homogeneous; base engine: TM2/TV2/TG6/TJ6/TD6/TP6/TL5/TL6/TI6
1AT Electronic stabilization program (ESP)
1G9 Space-saving spare wheel for temporary use, radial tire (5-hole)
2FU Leather trimmed multi-function sports steering wheel w/ Tiptronic
1NL Covers for alloy wheels
5RQ Right exterior mirror: convex
5SL Left exterior mirror: aspherical
TD6 4-cylinder gasoline engine 2.0 l unit 06J.D
0BM Rear stabilizer
3U4 Luggage compartment cover
QG1 Service interval prolongation
8AY Radio/navigation system
8GU Alternator 140 A
8ZH Antenna for AM/FM reception, diversity
1KT Disc brakes, rear (Geomet D)
1ZB Disc brake, front
G03 Front shock absorption
7MG Emission standard EU5
0Y1 Standard climatic zones
4UP Driver's and front passenger air bag with knee air bag and front passenger air bag deactivation
4X3 Side air bag front with curtain air bag
4R4 Power windows with comfort operation andcircuit breaker
4K3 Radio remote controlled central locking operated from inside and safe securing
N2T Fabric seat covering
5MD Decorative aluminum inserts
8RM 8 speakers (passive)
2JG Body-colored bumpers
E0A No special edition
0AE Front stabilizer
2UC Sports version
2G7 Filler neck module 1 with insert
UB1 Rear shock absorption for sports design
L99 Suspension range 99 installation control only, no requirement forecast
0YB Weight range 2 installation control only, no requirement forecast
Zakodowałem żeby podczas zamykania auta odzywał się też klakson, ale jst tylko ledwo słyszalny pisk, nie taki jak się spodziewałem. Więc tak naprawdę nie wiem czego mam szukać i skąd ten błąd.
Ostatnio zmieniony 06 lut 2018, 15:51 przez Piaseczeq, łącznie zmieniany 1 raz
  • Pochwały: 29
Re: Błąd 00134 a brak alarmu ????
Post06 lut 2018, 15:49
Golf kombi ?
Piaseczeq
  • Auto: MK6 GTI DSG
  • Silnik: CCZB
Re: Błąd 01134 a brak alarmu ????
Post06 lut 2018, 15:52
nie, 3D
taki błąd mi wywala,.
Tuesday,06,February,2018,15:58:29:10074
VCDS Version: Beta 11.6.0
Control Module Part Number: 1K0 937 087 J HW: 1K0 937 087 J
Component and/or Version: BCM PQ35 H 103 0615
Software Coding: 40180A3A8827F300408800807400892443550088736D8D60648000200040
Work Shop Code: WSC 00850 259 12315
VCID: 387B2CD33093
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 80
Mileage: 151723 km
Time Indication: 0
Date: 2022.14.11
Time: 14:48:29
Term 15 On
Voltage: 12.35 V
ON
ON
Term 50 Off
OFF
OFF
  • Online: 132d 21h 44m 40s
  • Pochwały: 23
Post06 lut 2018, 16:31
sprawdz wiazke a jak bedzie ok to obstawiam ze syrena do wymiany
Piaseczeq
  • Auto: MK6 GTI DSG
  • Silnik: CCZB
Post06 lut 2018, 16:37
Najlepsze jest to że klakson też padł.... :banghead:
  • Online: 49d 15h 47m 19s
Post06 lut 2018, 16:58
A bezpiecznik SC17 jest dobry?
Piaseczeq
  • Auto: MK6 GTI DSG
  • Silnik: CCZB
Post06 lut 2018, 17:23
Bezpiecznik pod maską dobry. Jak naciskam klakson na kierownicy to na bezpieczniku nie ma napięcia. Tak ma być ? Ściągnąłem kiedyś kierownicę żeby dostać się do tempomatu ale sprawdziłem i nic nie jest rozwalone/Nie podpięty. Złożone dobrze
maximus
  • Online: 8d 14h 18m 23s
Post06 lut 2018, 20:36
sprawdz bezpiecznik przy drzwiach - F17(5A)
Piaseczeq
  • Auto: MK6 GTI DSG
  • Silnik: CCZB
Post06 lut 2018, 20:56
Sprawdziłem wszystkie bezpieczniki w całym samochodzie. Ściągnąłem jeszcze raz poduszkę powietrzną żeby zobaczyćczy kostki powpinane, czy nie urwane coś. Kiedynaciskam klakson to nie ma napięcia na bezpieczniku 17 pod maską.
Zakodowałem żeby klakson działał jak zamykan czy otwieram auto, to jest tylko takie "cyknięcie" z okolic prawego błotnika. Wywala dalej błąd który jest w temacie postu. Gdzie dalej szukać ? Przekaźniki ? syreny ? Kostki ?
maximus
Post06 lut 2018, 21:02
zapewne masz 2 syreny w samochodzie, mala szansa zeby nagle obydwie padly ale dla pewnosci zdemontuj jedna i podepnij na krotko czy jest sprawna. nie wiem gdzie jest umiejscowiony przekaznik do klaksonu (tu moze ktos inny Ci podpowie) ale okolice prawego blotnika to raczej miejsce w ktorym montowana jest syrena alarmu
  • Online: 34d 18h 29m 3s
Post08 lut 2018, 15:52
Spytaj w ASO po VIN żeby Ci syrenkę poszukali, bo ta lista co podałeś jest niepełna.
yox
  • Online: 9d 30m
  • Auto: VW Touran 1T2
  • Silnik: BXE 1.9 TDI
Post08 lut 2018, 20:35
... więc wykoduj spowrotem to co zakodowałes i sprawdż czy są jakieś błedy ;)
Piaseczeq
  • Auto: MK6 GTI DSG
  • Silnik: CCZB
Post12 lut 2018, 15:44
Temat ogarnięty po dwóch wieczorach walki :)
Syreny sprawne
Przekaźniki sprawne
Wiązka sprawana
Taśma w kierownicy sprawna
Powód awarii - brak dobrego połączenia w kierownicy. Błąd także znikł na VAG. Temat do zamknięcia.
kkmw24
  • Online: 5d 9h 4m 43s
  • Silnik: 1.4 TSI 122KM Caxa
Post23 lip 2018, 19:42
mam taki błąd
014 - Defective
Fault Status: 01101110
Fault Priority: 4
Fault Frequency: 1
Reset counter: 214
Mileage: 154921 km
Term 15 Off
Voltage: 12.10 V
OFF
ON
Term 50 Off
OFF
OFF
Sprawdziłem bezpiecznik i jest ok, klakson działa, jak właczam i wyłaczam alarm to jest beep,
tylko nie działa syrena alarmu?
Jakieś podpowiedzi?
