08 lis 2017, 19:39
Test robiłem wszystko działa alarmu fabrycznie nie mam zaraz wklejenie cały autoscan
Wysłane z mojego Che2-L11 przy użyciu Tapatalka
-- 08 lis 2017, 19:44 --
03-ABS Brakes -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
40-AC Compressor -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
Part No SW: 03L 906 023 MN HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 8892
Coding: 08114014032401080000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM16TDI02103L906023MN 003004
ROD: EV_ECM16TDI02103L906023MN.rod
VCID: 7EF466D7E1E4D2CE2F-802A
1 Fault Found:
6060 - Body Control Module (Central Electric 2)
U0141 00 [047] - No Communications
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 23
Mileage: 202811 km
Date: 2017.11.06
Time: 15:32:59
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.lbl
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 113B200D092B0001880D04E4901F0051350000
Shop #: WSC 12345 123 12345
VCID: 7BF26FC3FAF6C7E608-802E
1 Fault Found:
01309 - Power Steering Control Module (J500)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 62
Mileage: 137092 km
Time Indication: 0
Date: 2012.03.31
Time: 18:08:20
Count: 3
Count: 2
Count: 12800
Count: 8212
Count: 52736
Count: 256
Count: 0
Count: 0
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0304
Revision: 00001016
Coding: 0000004803
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 7F0A9BD3E6EEDBC624-802A
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.lbl
Part No SW: 1K0 937 086 M HW: 1K0 937 086 M
Component: BCM PQ35 M 110 0651
Revision: 00110 AC
Coding: 40180A3880211EC0C06800433100A1ECCF790288F30D81606480A7230041
VCID: 3A7CAAC7B54C3EEE53-806E
Component: Wischer 04111 26 0512
Coding: 009795
2 Faults Found:
02391 - Terminal 30 Reference
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 136953 km
Time Indication: 0
Date: 2012.03.29
Time: 15:27:53
Term 15 On
Voltage: 12.85 V
ON
ON
Term 50 On
OFF
OFF
01179 - Incorrect Key Programming
000 - -
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 136953 km
Time Indication: 0
Date: 2012.03.29
Time: 15:36:58
Term 15 On
Voltage: 12.85 V
ON
ON
Term 50 On
OFF
OFF
Address 10: Park/Steer Assist
Cannot be reached
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Serial number: 003G5RAD3EW.
Coding: 00004431
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 316E8DEB603AFDB6E2-8064
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME31206671ZZZJ
Crash sensor for side airbag; front passenger side:
Serial number: 3582MSME76305265ZZZS
Crash sensor for side airbag; rear; driver side:
Serial number: 3512QSME40086337ZZZM
Crash sensor for side airbag; rear; passenger side:
Serial number: 3522QSME54046274ZZZO
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Revision: -------- Serial number: 90422KKN000N2
Coding: 5000140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 70E848EFABB0B4BEAD-8024
Part No SW: 5K0 920 872 A HW: 5K0 920 872 A
Component: KOMBI H33 0318
Revision: X0033005 Serial number: 00000000000000
Coding: 170923
ASAM Dataset: EV_KombiUDSMM9RM10 A04305
VCID: 2D56919B7C029956C6-8078
1 Fault Found:
12671232 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 57
Mileage: 136953 km
Date: 2017.11.06
Time: 15:06:02
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 181111F1000754
Coding: 350002
VCID: 3B72AFC3BA7607E648-806E
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 136953 km
Time Indication: 0
Date: 2012.03.29
Time: 15:44:27
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 136953 km
Time Indication: 0
Date: 2012.03.29
Time: 15:44:27
03075 - Parallel Parking Assistance Control Module (J791)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 136953 km
Time Indication: 0
Date: 2012.03.29
Time: 15:44:23
Part No SW: 5K0 953 234 HW: 5K0 920 872 A
Component: IMMO H33 0318
Coding: 000002
ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
ROD: EV_ImmoUDSMM9RM10_SE25.rod
VCID: 6ADC5A878D6C4E6EE3-803E
Address 37: Navigation
Cannot be reached
Address 40: AC Compressor
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0131316
VCID: 316E8DEBA83AFDB6E2-8064
Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 346084FF5728C89E89-8060
1 Fault Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 57
Mileage: 136953 km
Time Indication: 0
Date: 2012.03.29
Time: 15:30:03
Voltage: 11.50 V
DD
Temperature: 31.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0131318
VCID: 326C82E7AD3CC6AE9B-8066
1 Fault Found:
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
012 - Electrical Fault in Circuit
Address 56: Radio
Cannot be reached
Address 61: Battery Regul.
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0131280
Shop #: WSC 01357 011 1012551
VCID: 3566B9FB5C52D196BE-8060
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0131280
VCID: 3664BEF74154DA8EB7-8062
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661389278
Coding: 0E00000101010001
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 26446EB759F4AA0E07-8072
3 Faults Found:
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 136953 km
Date: 2017.11.06
Time: 15:30:29
13636608 - Control Module Incorrectly Coded
U1014 00 [009] - -
Fault Priority: 4
Fault Frequency: 1
Reset counter: 57
Mileage: 136953 km
Date: 2017.11.06
Time: 15:30:31
0022 - Radio
U1066 00 [009] - No Communication
Fault Priority: 6
Fault Frequency: 1
Reset counter: 57
Mileage: 136953 km
Date: 2017.11.06
Time: 15:30:30
End-------------------------(Elapsed Time: 03:04)--------------------------
-- 08 lis 2017, 19:46 --
radio mam androida dlatego nie mam polaczenia tego bledu w drzwiach pasazera tez nie moge sie pozbyc
-- 08 lis 2017, 19:49 --
a park ster mam odlaczony
