Monday,23,June,2014,15:23:02:62939
Data version: 20130910
VIN: WVWZZZ1KZAP141665 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
Part No SW: 03L 906 023 B HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 5863
Revision: -------- Serial number: 00000000000000
Coding: 00114016032400080000
Shop #: WSC 00028 028 00309
ASAM Dataset: EV_ECM16TDI02103L906023B 001005
ROD: EV_ECM16TDI02103L906023A.rod
VCID: 2541171F2414DD36C75-8070
No fault code found.
Readiness: 0000 0000
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 113B200D092600FB881104EA901E0041300000
Shop #: WSC 00028 028 00001
VCID: 78FF0E6BCB2690DEAC3-802D
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0008000002
ASAM Dataset: EV_Climatronic A01006
VCID: 7EF31873E102AEEEE6F-802B
1 Fault Found:
9481200 - Coolant Pressure
B10AB F0 [009] - Too Low
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 231
Mileage: 242268 km
Date: 2047.14.23
Time: 22:13:36
Part No SW: 1K0 937 086 D HW: 1K0 937 086 D
Component: BCM PQ35 M+ 103 0575
Revision: 00103 AG
Coding: 40180A3A9825F39040000080400081E443610088724D8560648000200000
VCID: 3169F34F68DC81962BD-8064
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 25021 21 0512
Coding: 009795
Subsystem 2 - Part No: 1K8 951 171
Subsystem 3 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5K0 919 475 C HW: 5K0 919 475
Component: PARKHILFE 8K H07 0008
Revision: -------- Serial number: 12941005319079
Coding: 100001
VCID: 3663C05381B2A6AE7EF-8063
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKD04GWS2
Coding: 00003132
Shop #: WSC 01383 790 00311
ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
VCID: 3B75D167B2907BC6811-806E
Serial number: 3572MSME02186350ZZZI
Serial number: 3582MSME304D2550ZZZQ
Serial number: 3512QSME1A264E05ZZZX
Serial number: 3522QSME2E1A4E63ZZZ3
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000034
VCID: 8305E987C2E04306091-80D6
Part No SW: 5K0 920 860 J HW: 5K0 920 860 J
Component: KOMBI H04 0308
Coding: 170F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 3365F9479AC0B386591-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 050310F1002692
Coding: E9A01F06000202000002
VCID: 69D95B2F408C395623D-803C
2 Faults Found:
02649 - Digital Radio Tuner
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 231
Mileage: 242268 km
Time Indication: 0
Date: 2047.14.23
Time: 22:12:07
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 82
Reset counter: 255
Mileage: 242268 km
Time Indication: 0
Date: 2047.14.23
Time: 22:12:03
Component: IMMO H04 0308
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA4230D8AB24EAA7-80BF
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2139
Coding: 0000052
VCID: 3365F94752C0B386591-8066
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 3169F34FA8DC81962BD-8064
Part No SW: 5K0 959 702 E HW: 5K0 959 702 E
Coding: 0000308
VCID: 3561C75F5CB4ADB6775-8060
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 195 AA HW: 1K0 035 195 AA
Component: Radio RCD510 022 0063
Revision: 00000001 Serial number: VWZ1Z3H7429351
Coding: 0500040004
Shop #: WSC 01324 785 00200
VCID: 65C1571F6C941D36075-8030
End ---------------------------------------------------------------------
Wszelkie pomysły mile widziane
