- Online: 6h 24m 3s
- Silnik: 2.0 TDI
Witam wszystkich,
Dzis przy odpaleniu auta zaświeciła się kontrolka check engine. Niestety ten fakt zaniepokoił mnie tym ze to już 2 raz.
Czy ktoś się orientuje co mogło pójść nie tak?
Możne ktoś miał coś podobnego?
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HW: 03L 907 309 R
Component: R4 2.0l TDI H23 9978
Revision: 42H23--- Serial number: 00000000000000
Coding: 00190012042400080000
Shop #: WSC 29230 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018 003014
ROD: EV_ECM20TDI01103L906018_VW36.rod
VCID: 67DDD1FA9EACFE7A01-8032
1 Fault Found:
5286 - Throttle Position Sensor (G69)
P0121 00 [232] - Implausible Signal
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 116899 km
Date: 2017.10.15
Time: 21:20:24
Engine speed: 41.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 81 °C
Intake air temperature: 20 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.240 V
Unlearning counter according OBD: 40
Air mass: actual value (mg/stroke): 426.8 mg/stroke
Throttle valve adapter: specified value: 0.00 %
Throttle valve adapter: actual value: 4.15 %
Throttle valve adapter: offset closed: -9.38 %
Throttle valve adapter: status-Bit 0: 0
Throttle valve adapter: status-Bit 16: 8
Throttle valve adapter: status-Bit 24: 55
Throttle valve adapter: status-Bit 8: 2
Throttle valve adapter: uncond voltage actual value: 994.0 mV
Readiness: 1 1 0 0 0
Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
Component: BCM PQ35 M 103 0615
Revision: 00103 AD
Coding: 40180A3A8825F3C040080080740081E443510088736D8560648000200040
Shop #: WSC 01357 011 00200
VCID: 35614BB29C805CEA43-8060
Component: Wischer 14121 26 0512
Coding: 009795
Component: RLS 151210 05 54 0403
Coding: 0330AD
Subsystem 4 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
2 Faults Found:
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 78
Reset counter: 59
Mileage: 110503 km
Time Indication: 0
Date: 2017.08.08
Time: 06:57:41
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
01598 - Drive Battery Voltage
Freeze Frame:
Fault Status: 00101011
Fault Priority: 6
Fault Frequency: 4
Reset counter: 47
Mileage: 114336 km
Time Indication: 0
Date: 2017.09.24
Time: 15:50:41
Freeze Frame:
Term 15 On
Voltage: 14.10 V
ON
ON
Term 50 Off
OFF
ON
Krzysztof
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 116899 km
Date: 2017.10.15
Time: 21:20:24
Revision: 00103 AD
Coding: 009795
Coding: 0330AD
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 78
Reset counter: 59
Mileage: 110503 km
Time Indication: 0
Date: 2017.08.08
Time: 06:57:41
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 47
Mileage: 114336 km
Time Indication: 0
Date: 2017.09.24
Time: 15:50:41
Freeze Frame:
Term 15 On
Voltage: 14.10 V
ON
ON
Term 50 Off
OFF
ON
Krzysztof
