- Online: 19h 30m 49s
- Auto: mk 6
- Silnik: 2.0 TSI 255km+
Czy może ktos pomóc takie błędy mi wyskoczyły, wg mnie to dolot, w sobote byl czyszczony, zrobilem na nim 250 km i rano wyskoczył Check Engine.
- Kod: Zaznacz cały
Tuesday,15,April,2014,13:27:11:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ1KZBW300291 License Plate: SG4419G
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0050
Revision: AAH18--- Serial number:
Coding: 0403000C1C070160
Shop #: WSC 01357 011 00200
VCID: E7DDDD17D6988F26B59-80B2
2 Faults Found:
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 55503 km
Time Indication: 0
Date: 2034.14.08
Time: 14:27:16
Freeze Frame:
RPM: 2033 /min
Load: 57.2 %
Speed: 82.0 km/h
Temperature: 77.0°C
Temperature: 12.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.224 V
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 55533 km
Time Indication: 0
Date: 2034.14.08
Time: 19:32:55
Freeze Frame:
RPM: 3411 /min
Load: 52.5 %
Speed: 137.0 km/h
Temperature: 94.0°C
Temperature: 9.0°C
Absolute Pres.: 970.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 057 C HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2727
Revision: 05351113 Serial number: 00001103311308
Coding: 0000020
VCID: 19392BEFD06C69D673D-804C
No fault code found.
Address 03: ABS Brakes
Cannot be reached
Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000002
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 6ED32833B162DE6E76F-803B
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AE
Coding: 40180A3A8825F3004088008074000BEC435D0088736D8D60E48000240040
VCID: 387FCE6B8BA650DE6C3-806D
Component: Wischer 28031 26 0512
Coding: 009795
Component: RLS 060411 05 54 0403
Coding: 0330AD
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
2 Faults Found:
01500 - Bulb for Fog-Lamps; Right (L23)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 123
Reset counter: 103
Mileage: 54765 km
Time Indication: 0
Date: 2033.14.29
Time: 12:58:47
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 4
Reset counter: 103
Mileage: 54765 km
Time Indication: 0
Date: 2033.14.29
Time: 12:58:50
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0012
Revision: -------- Serial number: 12501106701086
Coding: 108103
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA3N0PQ
Coding: 0000394E
ROD: EV_AirbaVW10SMEVW360_VW01.rod
VCID: 3169F34F60DC81962BD-8064
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME4251545EZZZX
Crash sensor for side airbag; passenger side:
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME5C6B745CZZZD
Crash sensor for side airbag; rear driver side:
Serial number: 3512QSME78261D42ZZZY
Crash sensor for side airbag; rear passenger side:
Serial number: 3522QSME42341E25ZZZR
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KD1001CQ
Coding: 1892140000
ROD: EV_SMLSNGKUDS.rod
VCID: 76E30053C932E6AEBEF-8023
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Serial number: 0031950
Coding: 830000
Part No SW: 5K6 920 881 HW: 5K6 920 881
Component: KOMBI H04 0206
Serial number: 00000000000000
Coding: 170F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: F2EBBC43255A7A8E127-80A7
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 070411F2003006
Coding: 350000
VCID: 306FF64B63D6889E243-8065
Component: IMMO H04 0206
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA4230D8AB24EAA7-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669748955
Coding: 010000
VCID: 285F1E2B5B06C05EFC3-807D
1 Fault Found:
03138 - Input AUX IN
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 55559 km
Time Indication: 0
Date: 2034.14.09
Time: 13:26:14
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 5K0 959 701 C HW: 5K0 959 701 C
Component: Tuer-SG 009 2117
Coding: 0004150
VCID: 326BFC43ADDABA8E527-8067
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 74 3201
Revision: 00H20000
VCID: 3467FA5B57CEB4BE40B-8061
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Coding: 0004406
VCID: 3365F94752C0B386591-8066
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1442908
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: RCD510 H16 5026
Revision: -----13S Serial number: VWZ4Z3L1124062
Coding: 0100040004
VCID: E5C1D71FEC949D36875-80B0
End ---------------------------------------------------------------------
